DazedNConfused
Sep 02, 2014Explorer
wa8yxm wrote:
Two thoughts.. You said you removed the outer cover, Did you also remove the cover over the condenser coils? This is where it really gets gunked up, in the "Backside" (Fan side) of the condenser coils.
Page 2. HOW HOT WAS IT (outside the RV that is) the hotter the more the compressor runs.
I'll admit it was a very quick inspection. I'll also admit I wasn't 100% sure what to look for...but was hoping if something at least look out of place, it would jump out at me. But this was one of those times I wasn't sure what I was looking for. I chose to spend more time with the A/C adjustments to see if I could find a pattern or t-stat position, but didn't come up with much. I would think, though, that if I maxed out the t-stat to the coldest setting...it would stay on longer than a few minutes at a time...and cycle more frequently that just a few times per hour...but I could be way off base here.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
