DazedNConfused
Sep 02, 2014Explorer
smkettner wrote:
Can just crank the bedroom thermostat to max cold... or is it?
Any chance you are running on 30 amp supply with an EMS load shedding the bedroom air?
I worked my way up to max cold...but that didn't seem to matter. I'm certainly no electrician, but I was plugged into 50 amps. I had enough voltage on each of the two legs...and when the compressor was running, it was demanding almost 20 amps from that leg -- so I believe there was ample power for the unit.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
