KeninAZ's avatar
KeninAZ
AC Efficiency?
I just picked up an older 2000 Fleetwood Bounder Class A. It's very clean.
But today, when I brought it home I plugged the unit into AC and tried the single roof AC unit out. The lowest vent temperature I can get is about 66° and the lowest temperature in the unit is about 84° with an outside temperature of 91° and very low humidity.
The dash air on the Ford chassis performs just fine but I find that the roof AC unit is a little lacking.
This MH is a 31' unit and I have no idea what the AC is on the roof size wise. The thermostat on the wall that controls it is a Coleman.
Maybe it's low on coolant and needs service?
Or are these temps I have provided about what it's capable of?
  • A properly sized AC unit should be able to cool 20 degrees below the ambient temperature. I suggest you get it serviced. A single AC unit should adequately cool a 31' RV in low humidity conditions.
  • I have gotten roughly about the same figures, on about 4 different units.
    Motor homes or fifth wheels in the 31'range with 1 ac. Called ac man, said that was normal.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 07, 2025
