I just picked up a second hand Jayco travel trailer and am having some issues with both the fridge and ac. The fridge can wait but the ac is a must in South GA. Here is the problem. We are running...
Is the thermostat set low enough. say like 70 degrees if it 80 degrees inside? Do you have a GFI that may have tripped the AC fan and circuit board are 12 volt the compressor is 120 volt So you need to make sure you have 120 at AC
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
