GordonThree
Feb 05, 2018Explorer
The relay should be a replaceable part. BUT
I'd go with DrewE's recommendation first; disconnect the existing thermostat and simulate a new one, touching the control wires to ground. You won't get a shock, it's very low voltage.
Specifically touch high fan wire to ground, and then without disconnecting, add the cool wire also to ground. let it run for a few min, and then disconnect all the wires. listen to see if the compressor stops. If it does, great, just need a new thermo. If not, bummer, probably need a new relay.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 27, 2026
