Terryallan
Apr 26, 2017Explorer II
Yes add a trans cooler, and a WDH will be needed with some type of sway control. Shocks or springs will not be needed. the WDH will take care of that.
As for weight. Desert Captain, and I disagree. I believe the yellow sticker dry weight is VERY important. That sticker will tell you exactly what the TT weighs sitting on the lot in front of you, including empty propane tanks, and battery. You will instantly know the weight of the TT with no fluids in it.
If that dry weight is within say, 1200lb of your towing capacity. you know it is too heavy. IF it is not close to your towing cap. you know you are good to go.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
