Lantley
May 07, 2016Nomad
N-Trouble wrote:gmc6000 wrote:Lantley wrote:N-Trouble wrote:.
I cant see 150lbs hanging off the back of a 30+ft trailer doing much to affect the handling. Probably wont take more than 50lbs off the tongue.
150# off the back behind the axles will take 150# plus off the tongue.
The weight will affect the performance/handling of the RV.
Sorry, but this could not be further from the truth. The only way this would be possible is if the trailer was perfectly balanced (front to rear) on the axles, which it is not.
150# on the back will do very little to change the weight on the tongue. I would be surprised if you lightened the tongue by more than 10-20 lbs at most.
Mount it and don't worry about it.
Good to see someone understands trailers AND physics.
Since you guys think it won't matter. At what point will it matter? 300#,500#, Is there a tipping point? Do you believe there is a tipping point or can you you just load up the rear as much as you like without affecting the TW?
