Cummins12V98
Apr 02, 2017Explorer III
This is where and how the head supports "SHOULD" be mounted unless you are dealing with a clearance issue. You should be adding some weight to the front axle. In the "OLD" days when a person had to physically lay out the hitch location it was "industry standard" to set 2" in front of center of rear axle.
The head supports each have a straight side and an angled side, keep the straight side towards the cab.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
