MFL
Apr 03, 2017Nomad II
Coming from 4"s behind the axle, should make for a better towing experience! I would expect that you would add a little more wt to front axle, but not a lot.
Your theory could be right, that being that far back with pin, causing some bouncing/chucking, maybe having some effect on tires. It does seem like once cupping of tires start, it seems to continue.
Thanks for the update, and good luck with the arms forward experience!
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
