TNGW1500SE's avatar
TNGW1500SE
Advice Needed
I'm looking to take a camper and turn it into a trailer to transport dogs from the animal shelter to places where they would been seen and adopted.
I'm thinking a 20 to 30 foot trailer that we'd remove all the interior and put in cages that are double stacked down each side. We'd add windows down both sides. It would have to have A/C and I'd use my 8000 watt portable generator to power the A/C. I could unhook and park the truck with the generator some distance away so the noise was not right in everyone's face.
A old camper seems like the platform to start with since it would have tanks and some of the stuff we'd need already installed.
Your thoughts?
  • rjxj wrote:
    It may depend on the make and model but I always considered all of the interior walls and cabinets to be part of what is giving rigidity and holding this junk together.
    X2, plus cutting windows in all down the sides would weaken it even more, might last till you made the first turn with it. :E
  • No, no, no. Use a heavy duty cargo trailer with air ride suspension. Have one more air conditioner than necessary, so if one quits for whatever reason, nothing will get too hot. Power each air conditioner with a separate generator. Each HVAC system will be independent. If you had just one system, a life threatening situation would occur if the A/C stopped. If traveling when the failure occurred, it would be too late before you knew it.
  • That could be a rough and dangerous ride for the animals. If you have a trailer ride a few blocks in it.
    Then think about rough roads. Yes I know you will stay off rough roads. That is until you can't. Potholes, road construction.
  • This would be a very unpleasant ride for the animals. not a good idea.
  • It may depend on the make and model but I always considered all of the interior walls and cabinets to be part of what is giving rigidity and holding this junk together.
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 18, 2025
