Gjac
Dec 27, 2014Explorer III
If your FG is highly oxidized the Starbrite product has a lot of cutting compound and works well at least on boats. One word of caution boats generally have thicker gel coat than the sidewalls of a MH. It is easy to burn through 10 mils of gel coat and expose fibers with a buffing wheel and Starbrite. I would start with the Maguires compound sold at HF and use their buffing pads also. The lighter compounds take longer to remove the oxidation but is safer. If you take a small area and rub that area by hand with a cleaner wax and the shine comes back the Maguires or any compound or cleaner wax will work well with a buffing wheel. Some MHs have Filon side walls like mine where you can see the fibers through the gel coat. This will be a lot of work and if you have good shoulders will be worth it, if not the Zeps treatment works well for older highly oxidized MH's.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
