OSCBRADLEY's avatar
OSCBRADLEY
Advice on buffer pads and wax needed
Hello Friends:
I have a 2000 Itasca Suncruiser with fiberglass sides. Fiberglass is in "ok" shape with some oxidation but not to awefully bad. I have purchased the Porter Cable 7424XP 6 inch variable speed polisher. I am just overwhelmed at all the fiberglass cleaners and waxes that are out there and then I am just not sure what type of pad to use, I'm thinking the yellow color foam ones seem fairly standard but I could be wrong. A couple waxes I am looking at are Gel Coat Labs Gel Coat Fine Cut Polish for RV's or boats and another called 3M Marine Restorer and Wax. Both seem to have fairly high reviews on Amazon.
  • FYI...these are the instructions to apply Sea Power For Machine Use: Apply SeaPower Cleaner and Wax and buff a small portion at a time. Buff until clear and dry and when entire area is finished, wipe off excess with a clean soft cloth. At first I applied it like a normal wax and tried wiping when dry. Buffing until its clear and dry made the job much easier! I did have to change pads often.
    Here are a couple of photos of the job in progress.
  • Thanks SH, looks great!! hope mine comes out as nice!! Hard to believe but we are in the 30's here in Houston, soon as it warms up I'm going to get out there and start cleaning.
    I know Amazon sells Seapower but I would assume just about any marine store would as well?
    I got it at the local marine store (LFS). I am sure most marine supply stores will carry it, Collinite, and/or Starbrite. They are all good products.
  • Poli Glow is my method for a nice shine and much easier than any wax I have used since 2001 plus it doesn't attack dirt.
    chevman
  • You have different color foam applicators for different uses--polishing, compounding, scratch removal, etc. Same with different finishing products--polishes, rubbing compounds, etc.
    Most of the major wax companies have products specifically designed for dual action polishers, and they don't put swirl marks in if used with the right foam pad. I use Meguiars professional products on my Bennington tritoon boat to keep it looking like chrome.
    Google "auto detail suppliers" or go to AutoGeek.com for details.
  • Bamaman1-
    Funny you should mention AutoGeek, I sent them an email asking their advice on pads to use with the Seapower product a couple day ago.
  • OSCBRADLEY wrote:
    SH-
    What type of pads did you use with Seapower?
    I have a small "palm" buffer so the only thing I could find were terry cloth bonnets. They seemed to work just fine. I would have preferred foam but couldn't locate any. I had six bonnets that I would use during the day so I would not have to stop and clean them. Cleaned after the days work. I took my time and finished in three "easy" days. It could be done in less time. (37 ft. 5th wheel)
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
