OSCBRADLEY's avatar
OSCBRADLEY
Advice on buffer pads and wax needed
Hello Friends:
I have a 2000 Itasca Suncruiser with fiberglass sides. Fiberglass is in "ok" shape with some oxidation but not to awefully bad. I have purchased the Porter Cable 7424XP 6 inch variable speed polisher. I am just overwhelmed at all the fiberglass cleaners and waxes that are out there and then I am just not sure what type of pad to use, I'm thinking the yellow color foam ones seem fairly standard but I could be wrong. A couple waxes I am looking at are Gel Coat Labs Gel Coat Fine Cut Polish for RV's or boats and another called 3M Marine Restorer and Wax. Both seem to have fairly high reviews on Amazon.
  • Garry&Gayle wrote:
    I clean the pads using Simple Green and OxyClean, work the Simple Green into the pad then put into the sink with Oxyclean and let them soak a while then rinse them out, too expensive to throw out after one use. I have over 10 times on mine. The 3M products work great and they own Meguiars too.
    Thanks, I'll give it a shot. Without cleaning, I get at least a few vehicles out of a pad.
  • My preference is the Starbrite marine polish. I use a terrycloth bonnet for both application and buffing.
  • I clean the pads using Simple Green and OxyClean, work the Simple Green into the pad then put into the sink with Oxyclean and let them soak a while then rinse them out, too expensive to throw out after one use. I have over 10 times on mine. The 3M products work great and they own Meguiars too.
  • I went with a Flex polisher, although there are many cheaper alternatives, and McGuire's foam pads. I toss them too as they don't clean very well.
    Started using Starbrite polish on the new trailer, so far so good. Did half the truck hood with carnauba wax and half with the polish in the fall. So far the polish is holding up quite a bit better.
    I've always liked 3m products, from my autobody days, I don't think you could go wrong with it.
  • I have a Porter Cable and use the foam pads. They can be washed out and used again but I usually just toss it. I use the Maguires line of Marine products.
    Don
  • X2 for the SeaPower. Used it on my fiberglass sailboat for years and on our Montana. Easy on and off and if you don't want to wash the RV before you wax it still works great.
    If the gelcoat is really bad you may consider looking into PolyGlo. It's like varnish for gelcoat/fiberglass. Need to remove the old waxes first but the application of PolyGlo is easy, alternating coasts applied vertically then horizonally for a total of 6 coats. Then one light cleaning and and additional coat once a year.
  • We used the 3m Cleaner & Wax with a 6" polisher/ buffer and our came out very nice.
    The Restorer Wax is for heavy oxidation. The 3m website will tell you the product recommendation for the existing amount of oxidation.
  • Lots of good products available...the 3M one you mentioned is good. I tried a new product this summer on the recommendation of "Dr. Glass" (local fiberglass boat repair guy) called Sea Power. I had great results with it on our 2001 Alpenlite. I used a fiber bonnet but only because I could not find a foam one to fit my palm buffer!
Looking for advice before your next adventure? Look no further.25,154 PostsLatest Activity: Aug 08, 2025
