theoldwizard1
Jul 26, 2017Explorer II
tragusa3 wrote:
The sub-soil you're dealing with will partly determine what sort of prep you need to do. I'm on a very hard red clay. We just dumped the gravel, spread it out and used it.
Very true. If you are on sand, landscape cloth is very important as the gravel will just sink into the sand over time.
tragusa3 wrote:
We used "crusher run" and it is closer to cement now than gravel.
Crusher run has different names in different area. It is a combination of 3/4" and down to "fines". It compacts very well. If you are doing more than 4"-6" you should spread the first 3"-4" "lift" and compact that before doing the next "lift".
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
