jmtandem
Jul 26, 2016Explorer II
There are two issues. What you can pull with the truck and what you can carry as payload with a truck. A fifth wheel will typically have about 20-25 percent of the total fifth wheel weight on the pin plus add the hitch that can weigh another 150 plus pounds and you will soon run out of payload with most half ton trucks. For a travel trailer the rule of thumb is 13 percent of the total travel trailer's weight on the tongue. Never use brochure weights. Then add about 500 pounds or more for water, stuff, and don't forget to add the weight of people, dogs, etc. Most half ton trucks can tow the weight, many cannot stay easily within the truck's payload. Go for the three quarter ton truck and if you go fifth wheel a one ton is not excessive or overkill.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
