Y-Guy
Apr 10, 2020Moderator
For those casually looking at what they could tow four down the Motorhome Magazine Dinghy Towing Guides is a great place to start. It provide a great overview, but doesn’t get into many details.
For those that know more details; make, model, transmission, engine, etc. Then the REMOCO Towing Store is a great resource. It will tell you more details about towing; if you can, limitations, if you can’t or if a Lube Pump might solve the limitation.
But the ultimate authority is the actual Owners Manual that came with the vehicle. In most cases you can do a Google Search with the year make and model to find one online. Bu you will want to verify with the actual owners manual of that vehicle to be sure.
There are users that find out that they can tow four down just fine, going against what the manufacture states. If you go this route you’re on your own if there are any damages, this is why many won’t risk violating the warranty by towing against the owners manual recommendation.
Even vehicles that could be towed one year might not be recommended the next year, either changes to electronics, transmission, engine or the bean counters can all influence the change.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
