jffnkrn
May 23, 2015Explorer
AGM vs Lead Acid
Well, need some input: If two 100 amp hour lead acid batteries did the job for my usage in my old trailer, will one AGM 100 amp hour battery do the job in the new trailer. Typical usage when dry camping: up in the morning and after breakfast may or may not run generator, will as needed run lights, pump, exhaust fan, fridge light, radio and typical daily stuff. Evening time, usually after dinner, while she is doing dishes, clean up etc. run the generator for a couple hours give or take and make coffee if in an area not allowing gen operations early, then by evening, if the furnace runs, pump, lights etc then up in the morning and it starts again. So the new trailer will have led lights and old one had regular lighting. I am thinking I will be able to make it with one AGM group 31 100 amp hour instead of the two lead acid group 29 with a total of 200 amp hours. I am trying to eliminate the double battery situation without going ove about $250. Si input is welcome. Lifeline makes a GPL 31 XT with 125 amp hours. So I think I cando just one. Again, input is welcome.
Thanks Jeff
Thanks Jeff
