I will be traveling with my cargo trailer and pulling it with a Ram 3500 dually with airbags. The whole set up is no more that 5k in weight. What air pressure would you set your airbags?
The 5 psi is the UNLOADED pressure as the PSI increases with load. I would run my PacBrake bags at 5psi unloaded but when the 4,500# pin was applied the bag pressure would hit about 30psi.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
