AH64ID wrote:
I don't like using the airbags to compensate for tongue weight. If the WD hitch can't compensate for the tongue weight then it's too much TW for the truck, IMHO.
What I do is get the hitch setup with full tow weight and an empty truck with 5 psi in the bags before hooking up. That's the setting I always use on my WD hitch. I then use the airbags to get back to that ride height with added bed payload (sometimes as much as 2K on top of my 1.3K TW).
I have also found it to be a better and more stable ride if the truck settles 1-1.5" over an empty stance, otherwise it's too much air in the bags and it negatively effects the ride.
I have found the same thing. I use the bags to keep the trailer level, not to raise the rear of the truck. With my current WD set up, I'm running around 15-20 psi. That gives me about 1.5" of drop from the stock rear ride height. I did lots of experimenting with airbag pressures so they were accounted found when I finalized the WD measurements.
