Campin_LI's avatar
Campin_LI
Air Bags
Hypothetical SUV towing travel trailer with 1200 lb tongue weight
Question / clarification:
Without weight distribution hitch - back of truck goes down and front of truck goes up.
With weight distribution hitch - back goes up a little, front goes down a little.
No weight distribution hitch - pump up air bags to bring back of truck up to unhitched height. Front of truck is not high. Why is this. The same weight is pushing down at the hitch. I would think the front of the truck would still rise because no weight is being transferred to the front of the truck.
Thanks for your ideas / opinions.
  • Don't forget that some of weight is also moved to the front axle of Trailer
  • the bear II wrote:
    The airbags push down on the rear axle to raise the rear of the SUV up.
    I follow you but I see this a little different. The weight pushing down on the rear axle is the same with or without airbags, therefore, I think of it as the airbags pushing up on the frame to lift the rear of the truck up higher. Probably the same as what you are saying though (is the glass half full or half empty type thing).
    There is no effect on the weight that was lost off the front of the truck. The front should still go up.... but it does not.
    I'm wondering if most of the front end rise on the truck without weight distribution and without air bags is actually due to the rear drop when the weight is added to the hitch and not so much related to the weight lost from the front axle (dynamics of suspension, etc). After all, with a 1200 lb hitch weight, only about 200 lbs or so is removed from the front. It is almost equivalent to having a passenger in the truck or not. Maybe the suspension automatically absorbs that type loss? Just thinking out loud.
  • Basically, the weight distribution hitch transfers weight across the whole vehicle. Acts as a leverage point to send some of the tongue weight towards the front of the vehicle.
    Not affected by airbags since the hitch is attached to the frame. The airbags push down on the rear axle to raise the rear of the SUV up.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
