wa8yxm wrote:
dodge guy wrote:
My buddy has the Brake Buddy. Install is easy, just plug it into the power outlet, hookup and he monitor/control box in the MH, watch that it connects and your all done. It's a simple system and you can easily move it between vehicles, unlike you system that is only for the 1 car. I'm planning on getting a newer vehicle and will then have 2 available toads. ThenBrake Buddy will be perfect for that.
As I said good if you have a "Fleet" (2 is a fleet though in the example I think I used 20) .
But every time you put it in the driver's seat that is an install and if you mess up it can total the car's brakes (happened to me on a different system the dealer messed up the install on.. When will I learn to do it or at least check it myself).
and over time that is a lot of work. plus I've spoken to folks who confirmed they said "Oh forget it" for a short trip.. Murphy's law says that's when someone will run out in front of you and SPLAT.
With the M&G or the US-Gear system I had or any of the other fully installed leave 'em in place all the time you just plug it in (if that) 1-2 seconds and it's live.. Some of them you don't even do that.
Mark me down as another Brake Buddy fan. Have been using it for close to 10 years. Very easy and straight forward to install. You would have to be totally incompetant to mess it up. Never felt like leaving it off, even for short drives. Have changed towed vehicle 3 times and the switch over was easy (had to run light setup anyway so adding a 12V charge line and breakaway was not difficult).
