et2
Aug 03, 2013Explorer
Air brakes
We just purcased our new DP. Regarding the air brake system. Is there a air storage tank that needs to be drained for water. 2013 Fleetwood Expedition.
koda55 wrote:
You never ride your brakes when descending a steep hill. This will heat them up and you will end up with brake fade. No Braking. When coming down a steep hill select the proper gear. You let your speed or rpm build up, you then apply heavy braking to get you 5 to 10 miles under your safe speed. You then release your brakes and let it build up again till you need to use heavy braking again. Hopefully you also have an engine brake or an exhaust brake to assist you in descending a steep hill.
