wa8yxm
Dec 12, 2013Explorer III
If your tires are over 100PSI rated.. The higher the pressure the faster you can inflate or top off the tires.
Also, you will need (With either) a regulator for your air tools, the higher the pressure (With the same size tank)the longer you can hammer with an air wrench, hammer or chisel the longer you can spray the longer you can ______ before you run out of air.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
