ceaser_22000
Dec 13, 2013Explorer
TomHaycraft wrote:ceaser 22000 wrote:
Looking at getting the porter cable air compressor 6 gallon 150psi for basically airing up tires on TV and trailer but would like to run a few small tools off it is this a good air compressor for that type of work or should I upgrade to the Kobalt 2hp 175psi.
I've had the Porter Cable 150psi / 6 gallon unit for over a year now. Solid little compressor. I use it for tires and blowing water lines between each trip in the winter. For an RV, serves the purpose. As others have mentioned, to run air tools, especially paint sprayers, you will need something with higher CFM, but those quickly become less portable for the RV.
Thanks Tom that is exactly the advice I was seeking primarily I will be using it for the TT and TV anything has got to be better than the little 12Volt inflator I am using now.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: May 25, 2024
