Hank_MI
Dec 13, 2013Explorer
That is a good little compressor. Good for airing up tires and some air tools, like pneumatic nailers or staplers. Impact wrench, impact hammer, sand blaster, cutoff tool will drain it in less than a minute. If you want to run any of those type tools you'll need a bigger compressor, one with more CFM, not necessarily more pressure. A 200 lb compressor is useless if it runs out of pressure in a few seconds. Don't confuse max pressure with CFM.
Again, it's a nice compressor, portable and will do the job if you're not running tools that need a lot of air flow.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
