ceaser_22000's avatar
ceaser_22000
air compressor advice needed
Looking at getting the porter cable air compressor 6 gallon 150psi for basically airing up tires on TV and trailer but would like to run a few small tools off it is this a good air compressor for that type of work or should I upgrade to the Kobalt 2hp 175psi.
  • oil less or oil? either one would work well for you I have both one from menards a coleman and a job smart from tractor supply. one oil free the other oil use them both for the same things blowing out camper lines fixing tires filling inflatables at the lake they both run long periods when getting used and have held up well for several years. I have a harbor freight one that was 39$ we leave for blowing up inner tubes that one is a little on the slow side but does the job! check the cfm that will tell you which one fills faster.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
