samhain7 wrote:
I'm stuck here! 50% say nothing wrong. 50% say something wrong,
Why can't it ever be easy. Lol
Btw. It's night now. Almost the same temp but the unit is now cooling
75 and counting
If you have the unit set on low and the air smells feels damp it is frozen up. You will have to cut it off and just run the fan until it thaws. You most likely have a 13,000btu unit. You could change it to a 15,000. Some newer units perform better than what we are used to in the 13,000 and the 15,000units.
hate to tell you this but you don't have enough cooling capacity. Easily fixed but not inexpensive at a good Dealer and install another unit and maybe upgrading to 50 amp.
Being from Toronto I would think you have a cold weather package which should help with cooling as well as heating but apparently not that much
