pioneerclaims's avatar
Nov 04, 2016
Air Filters
How often do you clean or replace the air filters for the AC units on the ceiling? Also, is there a filter for the furnace system in these things?
Thanks,
Z
  • RV furnaces are 'air flow' critical........and have barely enough w/o filters
    NO filters and don't add one or you could easily end up with a furnace that will not stay running IF you can get to run.
    A/C filter....thin foam material that can get dirty quickly
    Monthly at minimum.
    Buy a bag of A/C foam material at hardware store...cut out several to fit.
    Then you can swap out as needed while you wash/dry used one.
    Then when they tear.....toss them out
  • If you use the AC a lot then I would check it at least monthly and if it's dusty, a lot more often than that. Fortunately it's easy to do.
    I've not seen a RV furnace that has a filter.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
