dodge_guy
Mar 18, 2016Explorer II
Bobandshawn wrote:
You are right Tom. But the OP needs both. His suspension is dropping more than he wants, air bags will take care of that. A good WDH will get his front end down. His poor ride experience was probably due to his rear end going to bottom out land which is a crummy place to go.
The rear is dropping more because there is no WD! Once you install and set up a WD hitch, there will be minimal sag which is normal. Some of that weight on the rear axle will be moved to the front axle. Now if he loads a golf cart or a quad in the bed then he will need (maybe) airbags for that load.
The OP first needs a WD hitch before he knows if he needs any airbags!
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
