ctilsie242's avatar
ctilsie242
Explorer II
Mar 01, 2018
All windows open in covered storage?
Are there any issues with leaving windows open, including the top vent when a rig is in covered storage (i.e. under a pole barn with side walls, which keeps rain from blowing in.) With the screens on the windows, insects shouldn't be a problem, and it should keep humidity on the inside from becoming an issue or causing damage.
  • You'll get lots of dust in there requiring a lot of cleaning.
    Bill
  • Crack open a window at each end of the RV, and crack open any ceiling vents, and you will have no moisture problems.
  • Why would you want all the dust to come in? We just keep open our ceiling vents and have little dust. We store outdoors.
  • Unless there is a source of humidity inside the RV, it will always be close to or the same as the humidity in the barn whether the windows are open or not.
    I keep my vents cracked and one window open a couple of inches.
    If the building is clean and well enclosed it will probably not be an issue. Sometimes dust can be an issue in pole structures.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Nov 02, 2025
