Blacklane's avatar
Blacklane
Aluminum Differential Cover Thermal Results
I recently installed a finned aluminum differential cover from PML Covers on my 2012 Chevrolet Avalanche 1500 that I intend to use for towing a travel trailer. In my previous truck, I had to replace the differential bearings, which is not a small task, so I wanted an easy way to drain and fill the fluid regularly in the hope of avoiding the same problem in my newer truck. So I wanted a good differential cover with drain and fill plugs.
I powder-coated the cover in gloss black to match everything else under my truck. Installation was simple. I replaced the differential fluid with AMSOIL Severe Gear 75W90. I used a paper gasket and used medium loc-tite on the screws. (I once had some diff screws loosen causing a loss of fluid).
I have a thermal camera and I had a chance to take thermal images of the differential before and after installing the PML cover. I took both images after towing a trailer for about an hour on a highway, followed by about fifteen minutes of slower, steady driving. I could not perfectly duplicate the ambient temperature, so one image is at 70F degrees ambient and the other is at 80F degrees. In the thermal images, you can determine the ambient temperature by looking at the frame temperature in the background, which is pink/purple/blue.
I assumed that the stock differential and axle had plenty of heat-dissipating area, since the oil can flow all the way down both axle tubes. A few square inches of aluminum fins would not add much. The thermal images revealed a different story. The stock differential temperature was mostly 170-200 degrees F while the PML differential was mostly 140-150 degrees F. The axle tubes are green colored, indicating that little heat is transferred down the axle tubes.
Click For Full-Size Image.
Full disclosure: I also sent this info to PML Covers who posted it on their website and sent me a tee shirt, so I guess you could say I have a bias. However, I think these results would be applicable to any similar differential cover.
  • Blacklane wrote:
    IAt mid-life, the fluid was replaced with AMSOIL 75w90 and it was full of oil when disassembled.
    Well, there's the problem. Actual testing against real world specifications (no, the "three ball test" isn't one) beats multi-level marketing fluff every time.
  • It's only a sample of one, so we can't draw any conclusions about the effect of the fluid change. Maybe it would have not failed, maybe it would have failed sooner, or maybe it made no difference. We have no way to know.
  • It is also possible that (some/ part) of the lower temp is because of the AMSOIL synthetic.
  • D@mmit. This thread just cost me a bunch of time, but may have also saved my bacon.
    I was researching my rear axle, AAM 14-bolt 10.5", and found that my model year bearing cap may have been assembled wrong. Common on 2010+ GM trucks.
    So now I've got to pull the whole thing apart to check it out. And while I am there, I will of course do new synth fluid and a new fancy cover.
  • Thank you for the information. I have been considering adding one of these covers for my Ford 8.8 that is under my F150. I like the idea of easier fluid changes.
    Thanks!
    Jeremiah
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
