SidecarFlip wrote:
If you want to drive on really nice smooth roads, roads like glass, I suggest the Upper Penninsula of Michigan. Roads are fantastic. You see, here in Michigan, road maintenance is based on a Lane Mile funding ratio and the UP has the most lane miles so they get the most road funding from the State.
Wrong.
The vast majority of lane miles is in the southern urban areas.
The UP benefits from two major things:
- The truck volumes are much lower. Yeah, you have some logging and other things but not even close to what a lane on an urban freeway sees to the south.
- The other is far less freeze/thaw. The UP generally has a short period of freeze/thaw at the beginning and end of the winter. Once it's solidly frozen (most of the winter), you effectively have a concrete subbase supporting the pavement (with ice acting as the concrete). If you could keep that year round, that would be the best subbase available. By the time you get a ways into Ohio, you don't see much freeze/thaw action (the freeze has to go deep enough. a light frost isn't the same in terms of pavement damage) Down in the south end of Michigan, it's the sweet spot where freeze/thaw happens for much of the winter. That kills pavements. When it thaws, you effectively get pockets of liquid water supporting the pavement above the deeper still frozen ground. Water doesn't make a good support structure.
