- tinner12002Explorer
goducks10 wrote:
Cummins12V98 wrote:
"No - the Andersen IS NOT a gooseneck hitch."
If it's not then why are using the chains?
Cause it's a ball mount hitch. A true gooseneck has the ball mount in the bed. The Andersen is on the top of the 5th hitch. No gooseneck pin box either.
Of course you already knew that.
The reason for chains is because some states aren't clear on what constitutes chains. Even though it's not a true gooseneck it is a ball mount and will fall under ball mount/coupler laws. JMO at least thats the way I would figure it. Better safe than sorry.
And how was someone suppose to know that he had the Anderson Ultimate hitch from the OPs orig post...I had an Anderson gooseneck hitch that had chain provisions...they do make them...guess the OP maybe should have explained better. - johndeerefarmerExplorer IIII use these as I have a gooseneck ball that attaches to my fifth wheel rails.
https://www.etrailer.com/Accessories-and-Parts/Reese/RP50223.html
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
