pressure_welder
Jun 22, 2019Explorer
Bedlam wrote:
Do you have the lower profile version of the hitch or standard height? Are you using a gooseneck or rails to mount it? If gooseneck, what make or model is it?
Ya I have the low profile version which I believe is standard for the truck flat bed model. It could actually stand to be a touch lower but still good for level. Iam using the existing recessed gooseneck ball that is installed on my flat bed so no rails or anything. And when you buy a hauler bed they come with a pre-installed gooseneck ball generally rated for 30,000lbs. I guess I also forgot to mention that the Andersen also destroys the B&w in quick height adjustment. Just have to pull a pin and raise or lower ball. Where as the B&W you have to remove hitch head, loosen 8 bolts, adjust had brackets, re-install bolts/torque. Again not the end of the world I did it many times but is a much more time consuming process.
Looking for advice before your next adventure? Look no further.25,188 PostsLatest Activity: Mar 24, 2026
