Rangerman40's avatar
Rangerman40
Andersen WDH without chains
Can you use the hitch by itself as an anti sway device if the weight distribution is not needed? I'm looking at a Ram with auto level rear air suspension and my camper is fairly small so I won't need the weight distribution but I would still like the anti sway capability of the ball. I've towed short distances without hooking up the chains on my current setup with no ill effects, but I was curious over the long term if it was advisable.
  • Rangerman40 wrote:
    I already own it for my current set up.....
    Then set it up and use it. You have nothing to lose and everything to gain. It will ride better, and it will handle better.
    The new RAM is a 1500 right? Factory receiver is limited to 500lbs of tongue weight before you need a WD hitch. That is a RECEIVER limit, not a truck limit.
    If your trailer's tongue is over 500lbs, you need the WD hitch even if your truck has auto-level.
    3500...... Hence the question. The class V hitch is good for 1800lb tongue weight which my trailer is nowhere near. I just want some sway control and don't need the weight distribution which is why I was wondering if I could get away without the chains. I already have the Anderson so I will continue to use it one way or another until I get a 5ver in a couple years.
