camperforlife
Mar 08, 2016Explorer
Rlarue wrote:
I to liked what I saw about the Anderson hitch, so I bought one. I tow a KZ Spre 260RKS, loaded weight close to 7,000 lbs, with a 2004 Ram 1500 5.7L Hemi. I previously used a conventional load distributing hitch, plus friction sway bar. I agree with the earlier post. While I like the ease of setup and break down and the minimizing of highway bounce on old concrete roads, the friction cone in the Anderson hitch does not seem to afford enough anti-sway control to my liking. I have added a friction sway control to my rig now and it gives better, although somewhat noisy now, control. It wasn't a difficult modification. The Anderson hitch using inert chains definitely has less highway "bounce" to it.
I had the same trailer and just traded it. I think your issue is more the trailer than the hitch. I never could get a comfortable tow unless I pulled with a full tank of water. Your dry hitch weight is under 500lbs which in my opinion is about 200lbs light for your trailer. Since the water tank is under your front bed it is pretty easy to fill it up to add tongue weight.
I traded for a 7' longer, 2000lb heavier trailer with 400lbs more tongue weight and it tows like a dream. I think KZ dropped the ball distributing the weight on your trailer.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
