SpeakEasy's avatar
SpeakEasy
Another ABRUPT Braking Situation
Yesterday I was on my way home from a camping trip about 3:00PM towing my 4300-lb (weighed) travel trailer. I was on a rural road that was winding and hilly; the speed limit was 55MPH. I was pretty much traveling at the speed limit. On the uphill climbs I was really powering into them to keep my speed from dropping too much.
I came to the crest of a hill, and around a blind curve ahead there was a stopped school bus with lights flashing and stop sign deployed. It was in my lane, heading the same direction as me, and there was a car stopped behind it.
I had to slam on the brakes to their maximum in order to be able to stop.
For a split second I was unsure I'd have enough room to come to a complete stop, and I did a quick visual check to see whether to use the opposite lane or the shoulder for an emergency. On what side were the children?
Fortunately, I was able to stop safely.
I was very glad for a number of things: (1) all my gear worked as it was supposed to; (2) I am within my weight limits; (3) I was paying full attention to the road.
If any one of those three elements had not been true, there could have been a bad ending.
Be careful out there, especially during school transportation times.
-Speak
  • The drivers manual use to say you should be able to stop in the distance you can see. You say you were "really powering into" and "blind curve", I don't think you were paying attention.
  • I allow my speed to drop as I crest a hill for two reasons, limited sight distance and the excessive braking going down the other side. Drives the proctologists crazy, but I don't care.
  • I knock 10 mph off the speed limit. If folks end up behind me, I pull over and let them by (when there are 3).
  • As a part time School bus driver it always worries me when a stop is over the crest of a hill, or around a blind curve. I have all ways request a sign be installed when needed and now most of our rural stops around here now do. that being said the driver of the other vehicles have to be paying attention, very easy to miss a sign. But what is worst is the guy in such a hurry he passes time you put the sign in. what if a child was walking on the side on the road, or needed to return to the bus, could become a nightmare real quick.
  • slow down when you can't see far enough ahead to stop without making an abrupt maneuver. YOU are responsible, not the bus stopped in the lane.. could have been broke down, etc..
  • You should quickly contact the school district or the highway people and urge them to install a "school bus stop ahead" warning sign or whatever is appropriate at that location. Soon it will be getting darker and another driver may not be as lucky as you were.
  • Nice driving, it could have been a very bad situation if you had been not on top of everything.
    -Speak
    I'm really glad it worked out for you, and you had nothing worse than a momentary adrenaline rush and maybe some rearranged cupboard contents come out of things.
    It's really, really easy to drive too fast on curvy and hilly roads--not so much because of one's ability to go up or down hills or around corners with command of the vehicle, but rather because of limited sight lines and being able to stop for unanticipated things blocking one's way. I know there have been a good few times when I've considered after driving somewhere that I would have not been able to avoid a crash if I came upon a downed tree or something around a blind corner or over a blind hill. (Even more frequently, it's likely that the driving is the same but the consideration afterwards doesn't happen.)
    Thanks for the reminder to pay attention and be prepared.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
