Mountain_Mama's avatar
Jan 27, 2015
Another blue tote concern
So as not to hijack another thread, I'm asking my husbands concern here. We use our tote rarely, but when we do DH will not pull it behind the truck. He loads it in bed of truck. He's concerned the axle will get too hot when pulling and melt the tank. I don't see this happening as I've never seen a post about such, but thought I'd post anyway...although it probably won't change his mind either! LOL! Your thoughts??
  • I might have to get me one of these tote thingys. It appears that I might be missing out on some fun others are having.
  • We have seen the axle heat up and you can guess what happened!! They were driving to fast. We use the macerator to pump the tanks into the back of our truck where tote will reside until we are done.
  • There a times when we couldn't get in a full hookup site at a CG. If it was just the DW and I, we could probably go several days before we had to dump but with a family of 4 (2 younger kids that really don't know the purpose of water conservation) we can easily fill the grey tank in 48 hours. The tote is a big space hog but it is necessary sometimes, at least in our case.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    One would hope the wheels turn on the axle, but ... I do know folks who have upgraded the wheels (another thread currently here in fact) and I have seen lots of folks tow 'em
    TOW SLOW, that's all i can say,, TOW SLOW like 5mph
    But if you want to load 'er into the truck,, No problem there either. If I had a truck I'd put a 55 gallon drum and use my macerator to fill it, then gravity dump.
    The wheel mod thread:
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/28169075.cfm
  • rhagfo's avatar
    rhagfo
    Explorer III
    GaryWT wrote:
    Speeds in campground are usually 5 mph so should not be and issue. On the other hand, would not want to be the person who proves the it is not a problem group wrong... Another reason we only go to full hookup sites, don't need a blue tote.
    We can go 8 to 9 days on our on board tank with two, washing dishes daily, and showering daily.
  • My axle doesn't rotate. The wheels have bearings in the center so all the friction/heat is on the sealed bearings.
    Now, I have replacement pneumatic wheels from Tractor Supply. The original wheels did have the plastic of the wheels rotate on the non-moving axle.
    Second point - I use a bungee cord to make sure the handle doesn't come off the ball as easily. I also usually have the DW pull the tote while I walk behind it to make sure to catch it if the handle comes off. And I need the exercise, and to make sure she keeps the speed down.
  • Speeds in campground are usually 5 mph so should not be and issue. On the other hand, would not want to be the person who proves the it is not a problem group wrong... Another reason we only go to full hookup sites, don't need a blue tote.
  • Like Ron3rd said, tow slow but I believe most of the moving friction is inside the wheel hub where it meets the axle and not where the axle is pressed into the tank.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    We've never put our tote in the bed of the truck. Huge waste of effort IMO. Totes are MADE to be towed. Yes, you could overheat the axle if you tow too fast. That's why you're limited to something like 5 mph to prevent this. Never heard of anybody burning up an axle btw.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 26, 2025
