taylor6400's avatar
taylor6400
Another can i tow this question...kind of
Let me preface this by saying we are permanent campers, and don't travel other than that. This was our third year and I don't see us doing anything different. We love the place, out neighbors, and its pretty close to home, and with a kid in sports if we weren't permanent I don't think we would camp. But we are upgrading our camper from a 25' to possibly a Keystone Hideout 31RBDS. I know its more than I would tow on a regular basis with a half ton. But I only have to get it 60 miles to my camp site then its staying there.
Heres the numbers, I have a 2014 Silverado crew. GVWR is 7200. Max payload is 1710. Rated for trailering 9100. Gross combined 15000. Curb weight of truck 5456. Camper is 7600 dry, 9600 GVWR, tongue weight listed at 865 (im guessing this is based on dry weight?). I know its right at the limits, but looks to be within specs. My truck will be empty with just me, camper will not have water but will have 2 batteries and 2 30b LP bottles. I have a weight dist hitch and sway bar. What are your thoughts?
  • I think you can be far less than the GVWR of the RV if you just carry minimal stuff when you move it. take one battery and one LP bottle in another vehicle. your RV will NOT be "fully loaded".
    bumpy
    Of the THREE half ton sub classes...this +7.X K GVWR is the middle
    or regular half ton
    This is based or derived from a 'curb' vehicle, which is the stripper
    version. Generally, the actual payload is less if your TV has options
    Even less when it is loaded with 'payload' or 'cargo'
    This is based on that 'curb' vehicle, so if your TV weighs more than
    the 'curb', that 9,100 lb rating is less by each pound over the 'curb'
    Go out and actually weigh your truck, fully loaded, in order to know
    where you are in reference to 'your' ratings
    Most will weigh hundreds more than their listed curb
    'Dry' is the stripper model in most cases. Most will actually weigh
    hundreds or more pounds when actually weighed fully loaded
    Yes, most are 'dry' tongue weights, but it does give a hint on the
    actual weight's percentage tongue weight. A lot depends on that
    trailers architecture and how you load it up
    Go out and actually weigh the whole setup, axle by axle. Fully loaded
    That is the only way to know where you are in reference to your ratings
    All this for sixty miles?
    Bruce
    or regular half ton
  • I've seen way worse combinations, but if you're buying it from a dealer and it's only 60 miles maybe they'd deliver it for a reasonable price?
  • If the hitch is set up right you will be fine but others on here all say you need an F450 with dual wheels and a tuner of some sort.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
