wa8yxm
Dec 02, 2016Explorer III
Much depends on your floor plan.. For example on my Class A I have water lines on both sides of the coach.. Currb side has the kitchen sink, water heater, water pump, LInes then do both up from the tank and down to the "Wet bay" and across, this is a heated bay on my RV so the lines have only forzen twice both time s well below 15 degrees (11 and 6)
Then they come back up inside the coach to the half bath, and along the driver's side wall (Inside) to the main bath, then wrap around the rear end (Still inside) to the shower.
You need to find 'em. but most of 'em are inside.. All trailers I've owned or worked on were the same way, Mostly inside.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
