sgfrye
Mar 01, 2018Explorer
JBarca wrote:
OK good, now we have more to work with and be able to help more.
I'm assuming this statement is true. Please Confirm you weighed the camper all by itself on the scales. Or is this a calculated value from some other weight slips?sgfrye wrote:
Loaded to camp with 2 empty grey ranks and approx 10 gallons in black tank our TT is 7000lbs weighed on cat scales unhooked from truck
Assuming you weighed it by itself like you stated, this means the GVW of the trailer loaded is 7,000#
Since your GVWR is 7,720# that means the trailer has 7,720 - 7,000 = 720# more cargo capacity left in the camper.
Now let's look at the setup.sgfrye wrote:
Weighed truck on scales with me in drivers seat.
Steer axle 3800 lbs
Drive axle 2840 lbs
6640 lb total
Truck and TT together
Steer axle 3420
Drive axle 3920
Trailer 6300
Gross weight 13640
I got trailer weight 7000 by subtracting truck weight from gross weight. Maybe that was wrong? 6640lbs truck -13640 total weight on cat scales =7000
Tag on trailer has 7720 gvwr.
Axles are 2 x 3500lbs gawr
If you weighed the truck by itself, and got 6,640# GVW and you subtract the GCW (gross combined weight) of 13,640# then yes, 13,640 - 6,640 = 7,000# is the trailer GVW.
But you cannot determine a loaded TW from your scaled numbers as the WD was engaged. You would need a 3rd weight, trailer hitched to truck but no WD bar tensioned up. Need truck front and rear axle and TT axle weight with that setup. Since there are no WD bars, then you can subtract the truck hitched weight with no WD bars from the unhitched truck weight and the gain would be the TT loaded tongue weight.
Your WD on the truck looks very light on the front end. You are 380# light on the front end. I do not know what year your F250 is. The newer ones they want the front end to be between 50% to close to 100% restored front end weight. Again you need the 3rd weight set to sort that out. But I can tell by your trailer weights you are light on the front. Need some more tension on the WD bars.
To this statement,sgfrye wrote:
I have no need to add 1420 lbs of cargo but would like to know where I stand if I wanted to tow with fresh water and more supplies
Your 1,420# cargo number is not right. You only have 720# of cargo capacity left on the camper. An issue is you do not know your loaded tongue weight. That is very important as adding fresh water may raise it (good) or lower it (can be bad depending)
If your fresh tank is directly over the axles, adding water to the tank is close to neutral to tongue weight, you gain GVW but it may not affect the loaded TW. It will however lower the percentage of loaded TW per GVW and that too may not be good depending on what the numbers are.
If the fresh tank is forward of the axles, then some weight will add to the axles and some to the tongue. How much depends on where the tank is located. Closer to the axles means less TW gain. Closer to the front of the camper means more TW gain.
Since it is a rear kitchen, yes adding weight forward of the axles is a ideally where you want to add it. You "might" be able to add some gear in the kitchen but again you need to know the current loaded TW so you can determine what percent the loaded TW is per the loaded GVW. On a TT, ideally this is 12% or higher for natural low anti sway on the trailer and to allow some room for cargo to change from trip to trip and not go down into the 10% or lower area. You have a good truck to hold the added TW and bed gear, you just need to optimize the setup.
Your trailer axles are rated for 7,000# GAWR. You have to watch that too to not go over that rating or overload one side of the camper. But since you can only add 720# total before reaching the 7,720 GVWR of the total trailer, odds are you do not load all 720# right on the axles.
If you have a front bedroom with a front large pass through cargo hole, adding gear under the bed and in the cargo hole will add a good amount of tongue weight. This can help allow small gear to go into the kitchen or axle area.
The fresh tank, need to find out where that is located and hopefully it is not behind the axles. Most TT mfg's know rear kitchens are tail heavy and put the fresh tank forward of the axles but not always.
This is truly a balancing act... The good news is, you are trying to sort it out and you are learning in the process. Good for you!! Not all take the time to do this.
Hope this helps
John
And that's why I joined this forum .... learn from experience
Great info from everyone thanks
Basically
Truck is 2017 f250 2wd crew 4x2 gasser 3.73 rear
Did not weigh TT on scales with WDH disengaged
I assumed total total weight of truck and TT minus truck weight would equal what TT actually weighed
I felt by the numbers front of truck was a bit light but wasn't really worried based on the way the TT towed which is effortless and when parked on level ground with WDH engaged the TT is dead on level as is truck
The only added weight I can see adding on longer trips is a few more groceries and maybe 10 gallons or so of water in fresh tank for bathroom breaks on the road. Just the wife and I plus 4 small dogs
We pack light anyway. My rule is whatever gets packed in camper before trip has to come out when we get back home. Cuts down on accumulation.
Fresh tank is over axles
I assumed 720 lbs cargo was what was available but wanted to verify
I thought a bit more tension on bars might help front truck weight so may try that on next trip
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
