wa8yxm
Oct 12, 2014Explorer III
Me Again wrote:
Yeap, it is going to cross contaminate here, but not in thousands of RV parks around the country! Maybe their water sucks rather than blows!
In fact many older parks have some "Frost proof" Hydrants, these are the kind where you lift an handle to make water flow and push it down to make it stop.
These do, in fact, suck
The actual valve is underground, how far under is a variable, usually it is set in gravel and it's right on the undergound water line. It is a 3-way valve, when you open the hydrant to fill your RV it connects to the water line that is under pressure and you get water,
When you push it back down it opens a drain and water drains out of the vertical pipe so it can not freeze... IF you have a hose hooked to it, it can indeed suck up whatever is on the other end of that hose. (unless you add a vacuum breaker)
I used this type of hydrant on the farm, and have seen it in several northern campgrounds and a few southern ones as well.
It is no longer approved, but older parks may be grandfathered.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
