Lantley
Oct 12, 2014Nomad
TechWriter wrote:Desert Captain wrote:
IMHO: The water thief is nothing more than a sleazy way to get around the rules(that just apply to other people).
I'm not sure why this is such a cause celebre with you, but I typically use my water thief when someone has busted off the head from a fresh water fill line. (A water source intended to fill RV water tanks.)
However, when I fill my 100 gal RV water tank, if it's a choice between lifting 20, 5 gal buckets or temporarily connecting a water thief from a non-threaded connection -- I'm using my water thief.
I agree if there is a prohibition against using/filling too much water the sign needs to state it. I could fill my tank from buckets or I could use the water thief.
If water thieves are prohibited than one can just fill via buckets. However that doesn't resolve the consumption issue,if that is truly the problem.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
