dewey02
Oct 12, 2014Explorer II
Lantley wrote:TechWriter wrote:Desert Captain wrote:
IMHO: The water thief is nothing more than a sleazy way to get around the rules(that just apply to other people).
I'm not sure why this is such a cause celebre with you, but I typically use my water thief when someone has busted off the head from a fresh water fill line. (A water source intended to fill RV water tanks.)
However, when I fill my 100 gal RV water tank, if it's a choice between lifting 20, 5 gal buckets or temporarily connecting a water thief from a non-threaded connection -- I'm using my water thief.
I agree if there is a prohibition against using/filling too much water the sign needs to state it. I could fill my tank from buckets or I could use the water thief.
If water thieves are prohibited than one can just fill via buckets. However that doesn't resolve the consumption issue,if that is truly the problem.
It certainly addresses the consumption issue. By not making it easy, the CG is trying to dissuade people from filling 100 gallons at once. It is relatively easy to have the hose fill your tank. But lifting a 5 gallon bucket up to chest height about 20 times is not so easy. Most folks would put in less water via the latter vs the former.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
