Lantley
Oct 12, 2014Nomad
dewey02 wrote:Lantley wrote:
I don't doubt what your saying. But why is there no sign restricting/limiting the quantity of water be consumed? I could easily fill my 80 gallon tank using buckets if I had to.
I don't need to connect a hose to use lots of water.
Because most people won't do what you do, and campgrounds are designed and operated on the basis of what most people will do in a certain situation.
One thing we tried to avoid are negative signs that say "Welcome to your National Forests" followed by a long list of rules that say don't do this, don't do that, don't don't do that, etc. It isn't very inviting or friendly. Much better to design things that naturally direct the type of behavior that is expected. Not always successful at that, and for example, the occasional person filling a 100 gallon RV tank won't kill the system, but lots of people doing it lots of times just might.
You might be surprised at the number of things designed into campgrounds to influence behavior without posting signs everywhere.
Makes sense. But a little honesty might go long way. The newer rigs have pump settings that allow the RV to suck water out of a bucket without a lot of effort. If the sign told me not too use too much water I would adhere to it.
However if the sign tries to discourage me via psychology and doesn't really state the issue I would likely fill my tanks.
A straight forward sign stating the issue may help with compliance.
The no connecting a hose sign would not stop me but a do not use too much water sign would.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 06, 2026
