deweysmith5's avatar
deweysmith5
Anti freeze preference
After many years of just blowing out my lines in my previous trailers, I decided that I should use anti freeze in my new fifth wheel because the plumbing was a little more extensive. After installing my new winterizing kit I began to pump anti freeze through the pipes. Worked like a charm except I seemed to use a lot of anti freeze. After going through the first three gallons I purchased three more, a different brand, from a closer store. I did discover that I had left the outside valve on and half my anti freeze had spilled to the ground. However, I noticed this second brand had a strong odor. So all this leads to the question brought on by my ineptitude: is there a preferred brand of rv anti freeze that leaves less of a lingering taste when drained out in spring?
  • Community Alumni's avatar
    Community Alumni
    I use whatever I can find for the cheapest price. And I only need 1 gallon to do the job, including the traps. Water heater is bypassed. And after flushing in the spring we have never had a smell or taste problem.
  • I only use it for my drain traps. I do know folks that collect and reuse for a few years.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 20, 2025
