Caveman_Charlie's avatar
Caveman_Charlie
Explorer II
Oct 11, 2022
anti siphon device ?
Although my primary RV is a travel trailer I also have a old pop up camper I use occasionally.
It has a hand pump on the kitchen sink. There is simply a water tote below the sink with a 3/8 flexible line that you put into the tote. You pump up and down on the valve handle mounted behind the sink to pump up water and there is a pipe that shoots the water into the sink basin. It works good for what it is intended for.
The problem is that after pumping the water that is still in the line will try and slowly siphon (fall) back down into the tote. You can even watch the pump handle move position as it does this. This causes a suction noise back through the pumps outlet above the sink. This is right next to my head as I'm trying to sleep at night. (it's really a annoying noise) There is no real way to cork off the end of the outlet. What I need is something to put in the line below the sink that will keep the water from trying to fall back down into the tote and therefore no more siphon at the valve.
Sorry that I did not explain this well.
Does anyone have a solution to stop the hand pump from siphoning back down into the tote below it ?
