mkirsch
Jan 12, 2015Nomad II
While not absolutely mandatory, a 2.5" shank would eliminate on source of slop in the system. You can use the adapter sleeve, but the hitch fit won't be as solid.
If you're going to buy a new shank and a new sway bar, consider spending a little more to get a new modern WDH with the sway control integrated. The integrated systems work much better than the old friction bars.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 18, 2026
