I carry a bottle jack, 10 ton??, and I also have a 6x6 that has an angle cut into it with a flat spot on the top that I put either in front or behind the good tire on that side. Simply drive or back onto it and the flat tire will be off the ground enough to change it out.
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 23, 2026
