ulvik's avatar
ulvik
Any E rated tire in 205/75/14 or heaviest available.
I wanted to change out my wheels and tires to a 15" heavy duty wheel and tire but found out I don't have room to do so without a ton of work and welding to move one of my axels back because I have a Dexter axel on my TT. With that being said what is the heaviest duty 205/75/14 or 215/75/14 inch tire I can get for my trailer. I currently have a load range C tire with a max load range of 1750LBS. I would like to get above 2400LBS with as many ply's as possible.
    Ply "ratings" do not mean the actual number of plys in a tires.
    Stick with Load Range or the actual number on the side of the tire.
  • Tom Trostel wrote:
    Goodyear also makes the HMG 2020 for Uhaul. Some are sold online.
    HMG2020
    The HMG 2020 is only J speed rated (62MPH).
    The Kumho 857 is a D rated tire and is speed rated at 99MPH (if I recall correctly).
  • Hankook RA08 , a true D rated tire , over 2100# capacity, 99 mph, 8 ply; you will have to order online probably, mine came from busdepot.com. $500 for 4 shipped, and you only need 195R14
  • There is no good reason to increase the size of the tires and rims.
    A quick Google search shows that 215/75/14 is readily available in load range E.
